Some questions on VCO design
Adam2008
Member level 1
Member level 1
Hi All,
I am designing a cross coupled VCO using CMOS technology. Now I got some question of the tuning frequency.
The frequency is always much higher than I expected. It can not achieve the lowest frequency which the varactor is supposed to. What is the reason of this problem? Can I measure the capacitance of the varactor? I am using Cadence spectreRF.
Thanks.
mmm , strange
usually the oscillator will give u lower frequency due to alot of parasictics u didn't take into account in the hand calculation
khouly
    Adam2008
Adam2008 said:
Hi All,
Thanks.
Maybe the inductor model is not precise.
Or do you use smoe special structure?
Usually, the frequency should be low than we design.
    Adam2008
how much differnece between the calculated and simulated frequqncy
try to send a schematic of ur oscillator
thanks
khouly
    Adam2008
I am using one symmetric inductor. WIll the value of inductance be different from claimed in the manual?
mmm , maybe there is a difference between them but how much difference u have in the frequency
khouly
The difference is quite big. If the calculated max frequency is 4.5GHz, the simulated frequency is between 5GHz and 6GHz.
man , there is some error
may be u put the capacitor or the vacator less , than the design
recheck ur tank circuit
is it a crosscoupled oscillator
khouly
    Adam2008
mmm ,
the cross coupled oscillator add a parasitic capacitance due to transistors ,
u need to check the resonator , may be the varactors are not right
khouly
    Adam2008
How did you caculate the frequency?By programming or other quomodos.
Maybe your model is not exact enough.
I need knowing your means.
thank you.
    Adam2008
I calculated the frequency by f = 1/ (2 *pi*sqrt(LC)).
this is the right equation ,
C is the varactor capacitance + parasitic capacitances
L is the inductance of the coil.
then u have an error in one term of these
another thing , u may have an error in SpectreRF setups. did u follow the manuals and appnotes given by cadence
Khouly
    Adam2008
