kthkevin
Newbie level 3
Hello everyone,I have some questios about Mandrake10.
1. I use export PAHT=$PATH:/usr/...... to change the env var, but after reboot,the settings disappeared,why and how I can solve this.(how I can change env var through change conf file?)
2. the similar to question 1, i use ifdown eth0 to shut down ethercard,but when reboot, eth0 appears...
3. How to delete a env var and how to delete some contents in env var
4. I have installed xcircuit, but when I run it, tcl/tk windows appear says can not open xcircuit.so , but in fact, this file does exist.
5. How to install or run the elcectronic8.jar?
6. How to change the sevices when start, such as do not let mysql-d run when boot?
7. which version of magic can work on md10,i try 7.2.2 and 6.4.4 but can not successfully compiled
Thanks a million for your reply
