xiaoxianzai
In the architecture of DAC ,analog part usually use a bandgap voltage, and then ,transfer the voltage to current,where use a voltage to current circuit.
As for the graph below,it uses a op and a external resistor.
SO,i want to ask why it directly use the bandgap current? i think it is more convenient to realise.
if these v-i structure has some advantages for changing the input current through changing the resistor?
