[SOLVED] Some question about transistor analysis
ehsantech
Member level 3
Member level 3
Hello
Here is my circuit and dc bias point
and here is ac output voltage
question 1:the output amplitude is too much higher than Dc input voltage what is my mistake or spice mistake?
question 2:if we want to find upper and lower frequency ( cutoff) we should calculate (1/sqr(2))*Vmax and then find the frequencies?
question 3:in below output figure if we want to find upper and lower frequency ( cutoff) we should fine max DB of output voltage and then minus 3db?
question 4:is there any simplest way to find upper and lower frequency in two different above questions(2,3)?
At simulated gain of 190+something (46dB) and input voltage of 1V your funny simulator shows 190+something volts of output voltage. If you divide that "output voltage" with 1V you will get amplification factor or gain.
Upper and lower frequencies are always 3dB (0.707) down the max gain and has to be read on graph.
Your simulation software is defective. It should warn you that your input signal level is way too high at 1V. With a 1V input level then the output is a saturated squarewave, not a sinewave and the frequency response graph will be completely wrong.
The signal across the 1k load resistor should be a maximum of 13V p-p or 6.5V peak but with severe distortion because there is no negative feedback. Maybe the distortion will be acceptable if the output is reduced to 3V peak. Then the input level should be 3V/190= 15.8mV peak.
I do not know if your simulation software uses peak signal levels or RMS levels.
Your amplifier has one low cutoff frequency for the input signal, and another low cutoff frequency for the output.
Regarding the input signal, its AC portion acts through R6, C3, C2. You can calculate the time constant, and from that you derive its cutoff frequency.
Regarding the output signal, its AC portion acts through R3, R4, C1, and load R5.
Notice that if you adjust the bias carefully, you can center the output signal around 0V. Then C1 is not needed.
If you want larger output amplitude, reduce R3 & R4.
No mistake - that's normal with AC analysis, because the similator does a small-signal analysis. That means it calculates the gain of the circuit with a very small input voltage, then multiplies that by the input voltage you gave.
So if you give 1V input and it shows 100V output, it doesn't mean your circuit can actually give 100V out. It just means the output is 100 times bigger than the input for very small inputs. It may be a bit confusing at first, but that's the way most simulators work.
If you want to see what the maximum output voltage is, and what the waveform looks like, you need to do a transient analysis with a sine wave souce, not an AC source.
Yes, that's one way to do it.
Yes. I think this is easier - less calculation.
No, it's normal. See above.
I think simulation software should warn than the input signal level is much too high resulting in an error in the frequency response if the circuit is actually built and used with such a high input signal level.
