qqns
Newbie
Area that compiled in the bottom_up strateges is diffrent from in top_down strateges,the area has been reduced a lot.After combinationed to the top_level compile,the area compiled in block level is been changed and reduced.
Sum of block_level areas is equal to the area compiled in the top_down strateges.It's proof that the results of block_level and top_down strateges is no problem.There were no obvious errors and problems at the top_level.
Why the area been reduced after merged into the top_level compiled by bottom_up strateges?
If anyone has encountered this problem, please give me a hint.thank you!
