sreechoudhary
Junior Member level 3
Here i am posting some questions please give me the exact answers asap
1) What is the best/required bandwidth of a filter that you need at the input of an AD converter if one desires to convert a signal at a specific speed and with a certain number of bits ?
Note - The Shannon principle is NOT a correct answer.
(2) What can be observed at the output of an (ideal and noiseless) integrating amplifier when a uniform (white) noise is applied at its input ?
Note - The correct answer requires a deduction in the TIME domain.
(3) What is the kink effect, and how can one avoid it ?
thanks and regards
thanks and regards
