Some one tell me that 1 not equal 2 . It true?
OOP
Newbie level 5
Newbie level 5
How to solution ?
muruga86 said:
do you mean
if(1 != 2)
//true
else
//false
No ,I mean in the mathermatical
Is it a joke like
sin x ÷ n = six
your question is unclear , please kindly elabrate your question with an example?
maybe you mean the classic proof using beginning algebra presented here with an explanation of the fallacy?
hxxp://www.math.toronto.edu/mathnet/falseProofs/first1eq2.html
yeah.. i think he meant that sort of stuff... thou, a=b implies a-b is 0... and i remember yet another 1... it goes like this...
1 = 1
2 = 1 + 1 ( 2 times)
3 = 1 + 1 + 1 (3 times)
4 = 1 + 1 + 1 + 1 ( 4times)
similiarly, x = 1 + 1 + 1 + 1 + 1 + 1 + 1 + 1.... x times
now differentiating...
d/dx(x) = 1 = 0+0+0+0+... x times..
=> 1 = 0 <=> 2 = 1
good luck....
/cedance :)
differentiating is just calculating the rate of change. Two quantities that change at an equal rate are not necessary equal.
(x²-x²)=(x²-x²)
(x-x)(x+x)=x(x-x) /(x-x)
(x+x)=x
2x=x /x
2=1 false
Again a fallcy. When both sides of the equation become zero or infinite, no further algebra can take place. It is like saying
0 = 0
1 * 0 = 2 * 0
therefore 1 = 2.
Same is the case when you work with infinite.
1*0 = 2*0 = 0
=> either 1=2 or 0 = 0 but 0=0 so 1!=2
hi,
could u spot me an example, a function f(x) where its differential is not equal to the differentiation result... in my view, when y = f(x), then dy/dx is equal to df(x)/dx.... and is not the other way and so do we say a "constant"
that is only when we reverse the steps... when dy/dx = df(x)/dx then y is not necessarily equal to f(x) .... when diferentiating, always LHS is equal to RHS! the proof i gave is obviously wrong for different reasons.. :)
/cedance
