Some layers' CAM file(.pho and .rep) couldn't generate
edaboardman
Junior Member level 3
how to generate rep file
My top layer and bottomlayer's CAM file(.pho and .rep) couldn't generate,they used no problem before.
PADS report:" Maximum number of apertures exseeded"and stop export gerber file
when I check the target directory, there is only "xxxx.if" file.
why? how to deal with it ?
Thanks!
Look at this
JURS
the problem disappear strangely ,I don't know why/how/when it disapear......
I don't know wether I should happly or unhappy.
if it apear again, I will try this method!Thanks!
Check the aperture wheel settings... The max number of apertures per wheel, defined for the bottom layer would have bee less than the actual number of apertures used by the bottom layer.;
