sub263
AN75320 - Getting Started with PSoC® 1
The Cypress PSoC 1 (Programmable System-on-Chip) integrates a microcontroller with programmable analog and digital peripherals. Use the AN75320 application note to get started on the capabilities of PSoC 1 devices and the PSoC Designer development environment used to configure and program those devices.
[http://www.cypress.com/?rID=58639]
________________________________________
AN2041 - Understanding PSoC® 1 Switched Capacitor Analog Blocks
AN2041 explains the operation of PSoC 1's versatile switched capacitor analog blocks, and provides practical examples of their use. You can configure the switched capacitors to work in many different modes such as a comparator, amplifier, integrator, differentiator, ADC, and more. This application note explains the theory and application of these switched capacitor analog blocks.
[http://www.cypress.com/?rID=2899]
AN78646 - Integrated Power Manager using PSoC® 1
AN78646 describes power management - a critical component of System Management Control (SMC) for computing and communication systems - and explains key concepts of power management such as voltage sequencing, fault detection, voltage and current monitoring, real-time trimming, and I2C host communication. This application note will help you build a fully integrated power management system solution.
[http://www.cypress.com/?rID=63431]
AN78692 - PSoC® 1 - Intelligent Fan Controller
AN78692 demonstrates how to develop 4-wire BLDC fan control systems using PSoC 1. The application note demonstrates how the included Fan controller IP can be used to manage BLDC fans in a various configurations. AN78692 helps you to considerably reduce development time of fan control systems.
[http://www.cypress.com/?rID=62757]
