Freiheitpt
how much current the inductor can handle
To work that out, you need to know the saturation flux density (Bs) of the core.I mean, the max operating current with wich the inductor still works as a inductor.
I expect it depends on the application. For example with a mains power cable, the thick rubber/plastic sheathing provides good thermal insulation. At the same time the wire must remain cool enough not to melt or burn the rubber/plastic.Here's a link to another wire gauge table. Its ampacity values are much different than the other tables.
Yes, that's half right. There's two limits; the thickness (AWG) of the wire, and saturation of the core.
Yes. If you're using 24AWG then that's probably the limiting factor, but you can always use thicker wire.so, I have to see which is lower, the saturation of the core, or the AWG current rating. right?
edit: For high power, high frequency work e.g. SMPS transformers, you also have to worry about core heating due to core losses.
If it's just for high DC current with a small AC ripple, you only have to worry about wire heating and core saturation.
