[SOLVED] Some help on Altium 6.6
burnix
Newbie level 3
Newbie level 3
Bayonne - France
Hello. I'm new to the forum and to Altium. I work on it from 3 weeks and i have some question. At work i dont have access to youtube so i can only consult at home. So my major problem was : how to make a clear integrated lib. I explain. I try from 3 weeks to make int lib with schematic, footprint and 3d. I want to know how work Altium. When i modify something in the lib (3d models rotation) the new position doesn't appear when i generate my 3d bord, it place some 3d scare in place of my components.
I think that altium doesnt refresh the links betwenn file, and so point somewhere (i dont now where because files have change) to find components that are in int lib.
So if someone can explain that or have some doc, i thank it a lot.
P.S : Sorry for my poor fr-english !!!!!!
When I was working with this version of Altium I remember that I had similar problem with flat footprints. I didn't use 3D library then but every time when footprint changed it could't be upgraded in straight way. If I remember well I was deleting all components with this footprint from PCB and then upgrade PCB footprint from PCB library. Maybe similar way will give you result you want.
Hope I understood your problem properly.
