3) power diagram of reverse - forward (motor that automatically runs forward & then runs reverse after sometime with a timer) connection of 3 phase motor
4) controlling diagram of reverse - forward (motor that automatically runs forward & then runs reverse after sometime with a timer) connection of 3 phase motor.
Why do we use star delta combination ?
Draw some time sequence chart or diagram, so i can look, how you want that circuit work.
Put some timing values in diagram too.
Star Delta Start Up Principles
more precise explanation of the star-delta starting.........
it means we use star delta configuration to reduce the starting current to 67% ...... that's the huge advantage of it
and huge disadvantage is the low starting torque of the motor which causes late run up (or to take lot of time to reach the motor to its rated torque & speed) .... Am i right ?
tell me more about dual voltage motors ?
thanks
what does it mean by "on delay" (Relay timer) ?
How many types of relay timers are there ?
Hmm... lets think about that....How to check whether there are voltages on coil of a contactor ? The coil ( A1 & A2 ) voltage is 220 V AC .........
where to connect the meter probes ???
