owen_li
Full Member level 3
Hi.
I am a digitial circuit designer. I want to know what's difference between the digitial and analog circuit. And what is the advantage and disadvantage of the analog and digital circuit.
I found the power management chip is usually designed using analog circuit.
Can it be designed using digital circuit?
Last question, as we know PLL is an analog device. It is usually located in the digital IC chip. But why there is no ADC between the PLL output and the rest of the digital circuit?
Thank you!
Thank you!
