Some advice for 32 bit MCU beginners
UroBoros
Advanced Member level 2
Cochin - India
Hai All
I want to learn the use of 32 bit MCU's like ARM or any similer.
Dont know anything about that in detail.
Is it practical to such MCU's on a hobby level or a small scale industry level?
Which are the low cost trainig modules or target boards available for that purpose?
Will any " Sampling" technique for chips will work out for this? :D
Thanks
Picstudent
Re: 32 bit MCU beginner?
Hi
The best way to learn 32 ARM mcu is via building a project
Go to Olimex site : www.olimex.com and order a working board for the LPC2106
ARM chip + Wiggler {ARM ICE interface} {cost ~ $ 100 or less}
Go to www.rowley.co.uk site and Download "crossworks for ARM " evaluation
software install and run it
The rowley software is the only IDE I know beside the GCC who support low cost wiggler
You can also use GCC C compiler for arm but i have no expiriance with it.
learn how to create project and how to complie a source code
you can builde your own wiggler if you like sch.diag you can find in "leon heller" site : www.geocities.com/leon_heller
Search google for LPC2106 project
All the best
Bobi
    UroBoros
I started successfully with hard and software from:
www.keil.com
Varuzhan
    UroBoros
Maybe try an FPGA with 32-bit core
    UroBoros
you mean a 32-bit micro core on an FPGA, right?
is that as good as working with a 32-bit micro like one of the LPC series of phillips?
    UroBoros
yes, that's what I mean. "Is that as good" depends on what you are looking for... it's good in terms of flexibility, but may not be as fast depending on the FPGA and the ARM processor you are comparing to. What are your requirements?
    UroBoros
I think, you ought read some matter on the computer architecture, and then start a project such as the nnARM, experience the theory into the practice.
    UroBoros
Hai
Can I use the Olimex board with Keil IDE?
I have a keil CD with DK ARM. Any chance?
Any body using Keil ARM tools?
Picstudent
