solving piecewise functions using ode in matlab!!
cedance
Advanced Member level 2
Germany
suppose, i define a function f'(t) = t at say [0,1] and f'(t) = t² at (1,4] that is,
f'(t) = t 0<=t<=1
= t² 1<t<=4
i need to find the numerical solution to this differential equation using matlab. Please suggest me how to do this. I couldnt find anything out of the help from matlab.
thanks,
cedance.
solving piecewise in matlab
I have just read now your topic.
Well, it is not numerical, but what about Laplace transformation?
And what about if you define the function with the aid of heaviside step function?
e.g.: [0,1] : Heaviside(t)-Heaviside(t-1)
solving piecewise functions values
or you write two equations, as you did :).
You know the initial conditions for the first equation, so you can calculate the solution of the first equation. You will get the initial values for the second equation, then you can calculate the second equation and after you can merge the two solution vectors. What about this approach?
