arash rezaee
Member level 5
Hi every one.
I have +12volt power supply and I want to redundant them in my design. the simple way is to use direct path diode in both wire of 12+ powers. But as all you know, we have static and dynamic resistor in each diode. So approximately +12 will reduce to 11.3 or lower when the current goes high. So, Do you know any other solution for redundant the power supply? I am using Meanwell power supply to have +12.
Regards
Arash
Regards
Arash
