Solution For Whistle Responder's Oscillator
joni_bravo
Newbie level 1
Newbie level 1
Lahore,Pakistan
Sir I am designing a whistle responder and using an oscillator to create oscillation of 3KHz.I have to operate it on 3.6 volts but the oscillator requires 5 or 7 volts to create oscillations. whistel responder.JPG
here is the diagram..in place of sounder I am using a Oscillator and if I apply 7 volts to circuit 3.43 volts drop across the mic and oscillator is not operating..Kindly give me a solution .
Sir I am designing a whistle responder and using an oscillator to create oscillation of 3KHz.I have to operate it on 3.6 volts but the oscillator requires 5 or 7 volts to create oscillations. View attachment 85517
so you need an ic which can operate down to 3v or so. you should be able to find that quite easily these days
