Soldering Station Hakko 907 (Thermistor sensor)
mhl167
Newbie level 3
Newbie level 3
Hi my friends
I built myself a soldering station with atmega8 microcontroller and some electronic components. I have used it for my work. In my soldering station, I use the scroll mouse (in optical mouse) to change temperature with step " 1 degree Celsius".
On pcb there are two buttons that have three functions:
- First, to call quickly assigned temperature.
- Second, press and hold buttons for 1 second to set temperature for ones.
- Third, press and hold the left button for 2 seconds to assign temperature (example: 100 degree Celsius on standby ). Press and hold the right button for 2 seconds to assign time that soldering station on standby. Example: you assign 5 minutes for that button, this means that after 5 minutes the soldering station is on standby if you don't touch the iron and it will heat the iron at the temperature that you assigned (ex: 100 degree Celsius).
Besides, there is a vibration sensor in the iron. You can add it into the iron. I think that this thing is not difficult for you.
Note: You must set fusebit for atmega8 with internal RC 8Mhz
I hope that this soldering staion will be usefull for you.
Have fun.
3081707303_926050034_574_574.jpgDSC_0099.jpgDSC_0100.jpgDSC_0101.jpgDSC_0102.jpgDSC_0103.jpgencoderDriven_mid.jpgFree-shipping-50PCS-13MM-font-b-mouse-b-font-font-b-encoder-b-font-font-b.jpg
Schematic and PCB: View attachment 1.Soldering Station.rar
Firmware: View attachment 2.Soldering Station Firmware.rar
You can share source code firmware
