T
treez
Hello,
We have just found out that our LED footprint is wrong. We have had 200 LED MCPCB’s made up (100 LEDs on each one) with solder resist between the LED pads. –Now we find out that there should be no solder resist between the LED pads.
Do you think we must throw all these LED MCPCBs away?
The LED is the "WICOP2 Z8 Y19" LED by Seoul Semiconductor.
Page 8 of the Seoul Semiconductor App Note called “Wicop” says that there should be no solder resist between the pads of the LED. They say that it is because flux residue can cause short circuit between the LED pads and the flux residue more readily settles on top of solder resist.
Page 8 of the following....("PSR" = Photo Solder Resist")
http://www.seoulsemicon.com/_upload/Goods_Spec/WICOP_Application_Note_Rev2.0.pdf
Since when did solder resist *cause* short circuits?
