solder paste advice.
qweets
Junior Member level 2
hello
i am new to hot air soldering , i just ordered a cheap ATTEN AT858D+
i am unsure which solder paste to buy and can only seem to find a couple in my price range.
there are two below from the same company. I wonder are these any good? I am trying to repair a hard disc PCB by moving a rom chip to a new donor PCB.
thanks for your help : )
https://www.ebay.co.uk/itm/121275877627
For a repair any solder is good. If you solder by hand,the old PbSn 60/40 can be used. Soldering paste is needed for SMD if the heat tunnel is avilable.
