bob332
Newbie level 2
decided on a project and a atmega328 is on the board in the 32 tqfp package. i thought i could do it, but honestly, after receiving the parts, i think a solder stencil on a hotplate (ghetto way) would net better results.
now my question is has anybody used this solder-it stuff? it is at mouser - https://www.mouser.com/ProductDetail/Wahl/7459/?qs=wT7LY0lnAe2r5UPJoeJJnQ==
i can't find a data sheet for it but have found some info online line that it is liquid @ ~385F, which doesn't seem much higher than 60/40 solder. it is cheap and thought i would give it a try if you guys think it would work. i will be monitoring the hotplate (w/ 1/4"-1/2" Al plate on top for heat distribution due to coil temp irregularities around the surface and 2 temp probes).
my thought process is that w/ this setup, it will be heated up until flow, then turned of. w/ me soldering by hand, i see multiple heating cycles clearing bridges. what says the hive?
tia,
bob
tia,
bob
