Solaris 8: Up arrow key don't repeat last command?
dd2001
Full Member level 4
Full Member level 4
solaris repeat last command
Hi, all
My up arrow key, down arrow key won't repeat the last command I typed, anyone know how to set them under cshell for Cadence.
the OS is Solaris 8 SUN machine.
thanks.
solaris repeat command
Using "bash" shell?
If not..do it (o;
solaris terminal up arrow
Well, Since Cadence only needs C shell, I can't switch to bash
repeat last command sun terminal
use the command history
bash repeat last command
If you can use the ksh shell:
set -o vi
Press ESC then -h
Don't know if it will work in csh.
