Solar/wind hybrid battery charger
immikhan25
karachi,pakistan
Solar/wind hybrid
i am using wind mil of 24V 60A DC output and 24V 8A solar DC output.i need to charge the 24V 200Ah battery bank with these two power sources.how can i charge batteries with both of them at the same time?
Re: Solar/wind hybrid
I think that you have a two basic ways for connection.
First way is by paralelling of the two energy sources, after their serial bloking diodes (with commong ground connection), and after then you should connect a single battery charger (DC-DC converter), between energy sources and battery.
Second way is by using a two separate dc-dc converters (chargers), for each energy source, with paralelled output on the battery side.
Best regards,
Taner
:D
