dom444
Junior Member level 2
this is a very easy two axis solar tracker using the L298N dual H bridge board small mistake on diagram photo diodes are upside down but correct on board and 470uf and 100n go to ground. the board mounts above the driver board with 3mm rod.
corrected circuit diagram
--- Updated ---
