vimalkhanna
Full Member level 6
I need to design a 10KVA /50Hz inverter with >95% efficiency and HF operation at 33KHz or higher .I have N87 ferrites for use. .
The design needs to use IGBTs for output pulse switching and input supply of 350VDC from the solar panels.
Since the output is transformerless ,how do I achieve isolation from the grid ?How do I generate power for home load and changeover to grid ?
Can members guide me to design with PWM processor /software routine /etc for getting max. power conversion. Any help ,schematics ,circuit design ,drivers for IGBTs etc shall be a help.
