chand00786
Junior Member level 1
I am working on solar charge controller.I do not want to add a diode between solar panel and battery to avoid reverse current from battery to solar panel at night.I tried it with the following circuit but it is not working properly.it is always on whether the signal from MCU is low or high.If there is any problem in the circuit kindly rectify it.OR if any one has a batter design to solve this problem.
