devonsc
I'm confused regarding the connection of thies three portions, the solar panel, the battery and the motor. Do you guys mind explaining briefly how does the connection been done?
Meaning, does a solar car uses the solar panel to directly run the motor, however, if the solar panel couldn't produce sufficient output to run the motor, the source to run the motor will automatically being tap from the battery? Is this right?
OR
The solar panel is being connected in such a way where it constantly charging the battery used in the solar car and the power needed to run the motor is always being tap from the battery. In other words, there isn't any direct connection between the solar panel and the motor.
Advice needed....Thanks in advance
OR
