softwares on electronics
manish chhajer
Newbie level 1
Newbie level 1
hi,i am 2nd year electronics engineer from India.
I want to prepare a software on any topic related with electronics. Please,give me some idea for this as per my level. Please,also specify logic behind it.
thanks
I think you can just write a simple software to control the Parrallel port of the PC. This you can do easily with TC also. and from the hardware side you just need to connect LED's on the Data Lines of the parallel Port.
And you can make a simple program with which the user can control the Port the respective LED/LED's will Blink.
If you want to use the MIcro-controllers than you can do the same on the Controller Pin. You can make a pulse generator or other such things.
I hope this helps. Best of Luck.
