Software SPI and I2C in HiTech C not working
john blue
Advanced Member level 3
Currently, I have just tried out the software SPI and I2C. Both are not working. If I used the hardware based, then, i get no problem. But, I need one of them to be software based. Anyone can please help? Thanks in advance.
can you put the code here.. did you test it in proteus simulator???
seems to be header file problem... put the simulated output so that we can understand the problem better...
where did you get the header files from?????
hai john,
I am new to this forum to post.
"Currently, I have just tried out the software SPI and I2C. Both are not working. If I used the hardware based, then, i get no problem. But, I need one of them to be software based."
May i know what did u meant exactly "software based" and "Hardware based"?
Regards,
karthikkr
"Hardware based" means protocol working with dedicated hardware like MCU registers, maybe interrupt driven etc. "Software based" is when you make the protocol by yourself, meaning toggling clock by software and driving bytes bit by bit to port pin. This is also called "bit banging".
Bit banging - Wikipedia, the free encyclopedia
Ya i can understand bit banging. But this is what Mr.John meant is my question? we can see his code or the CRO pulses to figure out the problem.
Thanks for your reply
Not that I have encountered, but you certainly have a knack for finding Proteus' weaknesses. :wink:
Can you upload your Proteus Simulation and code?
BigDog
hi,
you may want to do the i2c protocol in software
there is a working example of software I2c here:
software I2c
the project is done with 8051 but I but I believe since it's just software I2c it should work with PIC
Hi
I have going to interface the MSP430f5438 with digital potentiometer MCP41010 by SPI communication.For that i have write the code as below.My spi had some problem because of that i am not able to write the value in the data registers.If you had any solution for me then please send me.
void spi_init(void)
//unsigned char spi_cmd,spi_data;
WDTCTL = WDTPW+WDTHOLD; // Stop watchdog timer
P10OUT |= 0x01; //Chip select
P10DIR |= 0x0B; // Set P10-0,3,1 to output direction
P10SEL |= 0xA; // P10.1,3 option select for the si and clk
UCB3CTL1 |= UCSWRST; // **Put state machine in reset**
UCB3CTL0 |= UCMST+UCSYNC+UCCKPL+UCMSB; // 3-pin, 8-bit SPI master
// Clock polarity high, MSB
UCB3CTL1 |= UCSSEL_2; // SMCLK
UCB3BR0 = 0x02; // /2
UCB3BR1 = 0; //
//UCA3MCTL = 0; // No modulation
UCB3CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
// UCA0IE |= UCRXIE; // Enable USCI_A0 RX interrupt
P10OUT &= ~0x01; // Now with SPI signals initialized,
P10OUT |= 0x01; // reset slave
void spi_write(unsigned char data)
while (!(UCB3IFG&UCTXIFG)); // USCI_A0 TX buffer ready?
UCB3TXBUF = data;
void main (void)
spi_init();
P10OUT&=~0x01
delay(1000);
spi_write(17); //command set for the digital pot IC
spi_write(0); //values given to the data register
delay(1000);
P10OUT|=0x01
