Software for spoofing MAC address on Linux
vaf20
Full Member level 3
Full Member level 3
MAC address problem
hi all
i have a PC and have not MAC address so what do i do to generate license for MAC dependent licensing to running some software?
thanks ahead
hi
MAC address returns to Network Card Interface and I think the LoopBack of the computer doesn't have any MAC address.
So without network crad you can't use this license.
if you find a virtual network driver that can accept MAC address you can use MAC dependent license.
Re: MAC address problem
hi gzn
is usefull this virtual MAC in linux OS?
tnx
does anyone know virtual network driver to solve this problem?
i ask in other word:
i have not network interface card so have not MAC address.is there any software or method to spoofing MAC address on linux?then i have MAC address and generate license.
tnx
hi vaf20
In Linux you can use this software
tnx verilog_crack.
can i use this utility as creating none exist MAC address?or this stuff is used as changer only which mean it must exist one MAC and then change it.
tnx again
Is it notebook , that you can not insert one 10 $ PCI Eth card ?
May be the last resort is to find the kernel get the socket implementation source and rewrite code as when socket data structure is read from kernel it will be filled with default MAC address ?
If socket part is not statically linked into kernel image it will be enough to recompile socket handling part without touching kernel .
vaf20 said:
tnx verilog_crack.
tnx again
I think yes,
It's easy tool for setting MAC address of a network interface.
so you can use it to change your loopback address.
I have a NIC and I use this tool to change MAC.
but I didn't use it without NIC.
Do this and let us know.
Tnx
In recent interfaces you can do:
"ifconfig eth0 hw ether 00:50:bf:39:e3:ea"
cheers,
stUch
