[SOLVED] so now what am I doing wrong (trying to use INTOSC)
techristian
Member level 1
Member level 1
Windsor, Ontario
so now what am I doing wrong (trying to use INTOSC)????
I HAVE NO CRYSTALS YET. So I'm using INTOSC. I'm not expecting the segments to make any sense at this point. I just want to display different patterns on a single DIGIT 7 segment display. I have set up PORTC to power it and I'm trying to drive it directly from PORTC without buffering to memory.
Right now, when I power up the PIC16F1784 NOTHING HAPPENS !
Disassembly Listing for 7segmentledinASM_16f1784
Generated From:
/home/dan/Desktop/MPLABX/test/7segmentledinASM_16f1784/dist/PIC16F1784/production/7segmentledinASM_16f1784.production.cof
30-Apr-2013 12:00:55 AM
--- /home/dan/Desktop/MPLABX/7segment.asm -------------------------------------------------------------
1: #include <p16f1784.inc>
2:
3: ;CONFIG1
4: ; __config 0x3FE4
5: __CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_OFF & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_ON & _FCMEN_ON
6: ; CONFIG2
7: ; __config 0x3FFF
8: __CONFIG _CONFIG2, _WRT_OFF & _VCAPEN_OFF & _PLLEN_ON & _STVREN_ON & _BORV_LO & _LPBOR_OFF & _LVP_ON
9:
10: delay equ 0x2d
11: digit equ 0x2d
12: digmask equ 0x2e
13: value equ 0x2f
14:
15: org 0x0000
0000 2805 GOTO 0x5 16: goto start
17:
18: org 0x004
0004 281A GOTO 0x1A 19: goto dummyINT
20:
21: start
22:
23:
24:
25:
26:
27:
28:
29:
30:
0005 3000 MOVLW 0x0 31: movlw b'00000000' ;MOVE ZERO TO ACC "W"orking register
32:
33:
36:
37:
38:
39: loop
0008 3024 MOVLW 0x24 40: movlw b'00100100' ;one
0009 008E MOVWF PORTC 41: movwf PORTC
000A 2015 CALL 0x15 42: call d250
43:
000B 302E MOVLW 0x2E 44: movlw b'00101110' ;four
000C 008E MOVWF PORTC 45: movwf PORTC
000D 2015 CALL 0x15 46: call d250
47:
000E 306D MOVLW 0x6D 48: movlw b'01101101' ;three
000F 008E MOVWF PORTC 49: movwf PORTC
0010 2015 CALL 0x15 50: call d250
51:
0011 3000 MOVLW 0x0 52: movlw b'00000000' ;blank
0012 008E MOVWF PORTC 53: movwf PORTC
0013 2015 CALL 0x15 54: call d250
55:
56:
57: ;loop forever
0014 2808 GOTO 0x8 58: goto loop
59:
60:
61:
62: d250
0015 3052 MOVLW 0x52 63: movlw 0x52 ;loop 52 times ?
0016 00AD MOVWF 0x2D 64: movwf delay
0017 0BAD DECFSZ 0x2D, F 65: l250 decfsz delay,f
0018 2817 GOTO 0x17 66: goto l250
0019 0008 RETURN 67: return
68:
69:
70:
71:
72:
001A 0009 RETFIE 73: dummyINT retfie
74:
8007 0000 NOP 75: end
Ok I just noticed something here.
MY TRIS COMMANDS ARE GONE.
I put them in lines 34 and 35 but they don't show up in the disassembly.
TRIS 5 ;set PortA all outputs
TRIS 7 ;set PortC all outputs
Dan
Did you selected bank1 where it resides? Error level 302 gives an error if it not suppressed.
