Snubber for flyback transformer.
I_think
Member level 5
Member level 5
Ref: https://www.edaboard.com/threads/159495/#post678002
Some doubts that still aren't clear are.
1) Do we need snubber ckt across fet with internal protection diode?
2) With flyback transformer, the flyback (or back emf) is in inverse direction with the input. then why is required fet voltage calculated as
flyback voltage + line voltage ?
3) Why RCD, Not just Diode, Like using freeweeling diode?
If you refer to the controlled avalanche breakdown capability of modern FETs, it can be utilized instead of a snubber. But then you get the power dissipation inside the transistor.
Because the flyback voltage across the transformer is inverse to the input voltage.
Usually, a flyback converter is intend to generate output voltage at the secondary, not clamp it to 0.7 V. In addition, you'll notice that duty cycle is related to forward/flyback voltage ratio.
Reactions: mgate
    mgate
    V
