vinodstanur
Advanced Member level 3
- Joined
- Oct 31, 2009
- Messages
- 751
- Helped
- 114
- Reputation
- 234
- Reaction score
- 114
- Trophy points
- 1,333
- Location
- Kerala (INDIA)
- Activity points
- 7,054
I want to use the sniff mode in HC-05 bluetooth module. But couldn't understand the parameters from the the datasheet.
Here is the AT command list **broken link removed**
In that , page number 14, (21. Set/ Inquire—SHIFF energy parameter)
I want to set the sniff mode to reduce power consumption, but the parameters are confusing...
In bluetooth module RN-41, I used the sniff interval, it is having only one parameter to be passed. But here there are 4 parameters. How can I set sniff interval to 1/4 th of a second? The documentation in the datasheet is not so clear..... Also there is no explanation....:sad:
