nikeplato
Junior Member level 1
Hello experts,
Issue: bridging between 3 adjacent pins at SMT
Given: an IC 36 pins with very fine pitch, 3 adjacent pins are conected together by a single wider copper trace by design.
Question: These 3 pins are getting bridged and Manufacturing Dept brought this up as an issue since it fails the optical inspection. I asked them to ignore this failure since I'm not bothered by the bridging (those pins needed to be tied together anyways)
But now they are saying there is another potential problem that 2 of the pins will "steal" solder from the third and this one would remain unsoldered. that would be because the higher mass of solder acumulated on the 2 pins will easily "attract" some solder from the third, in the extreme condition leaving it unsoldered.
I can't believe this could happen (I asked them to show me an example of such a bord and they didn't have one), since the capilarity between this third pin and the copper pad will strongly keep the solder there.
Please help me argue that. Is there any book/document clearly stating this?
Thank you,
nike
Thank you,
nike
