sms to control microC..pls help..!!
zent_88
Newbie level 1
Newbie level 1
hi..i'm using t610 SE phone to communicate with microC either atmel 89c51 or pic 16f84 . before that i need to test the phone with pc using hyper terminal but i can't find a serial cable for this phone ...does anyone can tell me the pin configuration and do i need to use a max 232 ??
Find any avaialable data cable for the phone. Even if you can get a USB cable for the phone, you should still be able to use hyper terminal since the cable normally has a USB to serial conertor.
