cupoftea
Advanced Member level 6
Equation 23 of the LM5149 datasheet (page 32) is incorrect for the input filter shown in
Fig 9_2 of page 31. Would you agree with this?
It totally ignores CD and CIN for a start. (bearing in mind that CF is likely to be a large 'lytic.
LM5149 datasheet
Also, on page 32 it says...
Would you agree, this is not accurate?, if the filters output impedance is ten times less than the SMPS Zin at all frequencies up to the x'over freq,
then there is no adjustment to the con_to_output tran func.
___---___---________________________________________________________________________________________________
Also, do you agree that the conducted EMC scan shown at bottom right of page 48 of the LM5143 datasheet (below)
(conducted EMC from 30MHz to 108MHz) will be all Common Mode emissions?
LM5143 datasheet:
LM5149 datasheet
Adding an input filter to a switching regulator modifies the control-to-output transfer function.
LM5143 datasheet:
