Lord Loh.
Full Member level 4
lm78s40
I am planing to design an SMPS using μA 7840 IC.
I have a schamatic from a textbook (Op-Amp and Linear IC - Gaiakwad).
What I understand is that SMPS have an advantage of small size. But the datasheet shows that the SMPS IC requires a DC bias. Where do I get this DB bias from? A simple rectifier or a linear regulator.
Should I have to use a linear regulator, There shall remain no purpose of using an SMPS IC.
How exactly is the SMPS to be designed?
