baileychic
Advanced Member level 3
SMPS Battery Charger Design Help
I am designing a SMPS Battery charger.
The AC 220V (180V to 250V) is converted to 325V DC and is fed to SMPS transformer. a 100 uF 500V Capacitor is used to filter the 325V DC.
My question is can I use single switch forward converter with SMPS transformer to get the DC-DC Converter working. I need to get 14.6V boost charging voltage after diode drops.
The Battery charger will be 12/24V 10A type. SMPS transformer will be designed to handle max 15A.
Power of transformer secondary side is 24V * 10A = 240W
As power requirment is less than 350W can I use single switch forward converter ?
