Smith chart problem in ADS
jihen
Junior Member level 3
Algeria
Hello, can anyone help me.
I have a rectifier as shown in attachment, and i want to make a matching circuit using smith chart utility . when i open it i got this problem. so please help me to solve it.
    kheirolah
    I also have this problem. why ADS_SmithChart Utility doesen't build "TLIN" in hiearchy subcircuit ?
Did you design the matching circuit ?? There should be sub-circuit that has already been designed before in it.
You cannot use this block as you wish..You have to design a circuit then you can place it in another circuit.
    jihen
i design my circuit and place smith chart but when i want to open it it doesn't work.
do you mean that i have to change the design ?
I mean have you ever designed the matching circuit by using Smith Chart Utility ?? If you have done, you should normally see the sub-circuit when you go into hierarchy down..
    jihen
Thank you sir :)
