Gaber Mohamed Boraey
Full Member level 5
Hello everyone
I have ups device with inverter board problem, there are some defect components, one of them is smd transistor with code N1P , I’ve searched and found equivalent number is bfr53,
which is 2Ghz wideband NPN transistor
Here is the link for datasheet
I have 1P smd transistor, which is 2222 transistor, can it be replacement?, if no, what common smd transistor can be replacement?
Any of attachments can be?
Waiting your suggestions for solve this issue
Regards
BFR53 Download
Download BFR53 Datasheet. File Size: 89.94 Kbytes. Part #: BFR53. Description: NPN 2 GHz wideband transistor. Manufacturer: NXP Semiconductors.
pdf1.alldatasheet.com
Regards
