SMD SOT89 marking code N130
dexter_04
Newbie level 5
Newbie level 5
Hi everybody,
Happy new year for 2024 !
A friend gave me a flow sensor from a water softener.
For the moment, I didn't success to identify the component on the sensor. I think it's a hall effect sensor, but even with the marking code (N130 ?), I don't know which is the reference of this component.
If somebody has some ideas, I'll be very happy.
Thank you
Hall sensor sounds reasonable. But I would look at the correponding sensor hardware to understand sensor operation principle.
Thank you for your reply.
From what I understood, there is a little magnet on a turbine. With the flow of water, when the turbine turns, the magnet passes in front of the sensor.
With that principle, the flow can be measured.
LaTeX Commands Quick-Menu:
