Cval
Junior Member level 1
I am trying to solder a SMD FET to my PCB, this is a different fet than the PCB was originally designed for (Drain and Source switched places). When i solder it up like this the R1 on my PCB ignites. Is there a reason you cant solder SMD FETs like this?
I also tried to solder the through hole version of the original FET to the board and the same thing happened...
