T
treez
Hello,
We are doing a 65A, 1V5 SMPS using cascade of Vicor Power PRM48JH480T250A00 module and VTM48ET020T080A00 module. Vin=48V.
We are seeing 30mV of ripple at the output voltage of the VTM48’ module, and even if we increase the external output capacitance from 329uF to 2329uF the ripple stays pretty much at 30mV.
(As you’d expect, the ripple frequency is 3MHz, which is the switching frequency)
There is 310uF of output capacitance internal to the VTM48’ module.
So we conclude that we cannot appreciably reduce the output ripple voltage by increasing the output capacitance, because this ripple voltage is mainly caused by the 1 milliohm of internal resistance inside the VTM48’ module. (page 11 of VTM48’ datasheet shows this).
Therefore, we believe that we should only add some high frequency capacitance at the output of the VTM48’ module. As such we wish to use ceramic capacitance with low internal inductance.
Can you confirm that generally the lowest inductance ceramic capacitace is gotten by using the lower capacitance values and the larger case sizes?
PRM module datasheet:
http://www.vicorpower.com/documents/datasheets/PRM48BH480T200B00.pdf
VTM module datasheet:
http://cdn.vicorpower.com/documents/datasheets/VTM48E_020_080A00.pdf
