KEØBRS
This is my version of a "small" crystal-controlled voice transmitter. It uses 5-transistor array chip, otherwise, it could easily be made with individual components. It transmits at around 166.900MHz using a 50MHz crystal. The input audio jack (for the microphone) is simply attached with the blue-white twisted pair and uses the "matched pair" of the array as a preamplifier. The signal is then fed into the oscillator section--a crystal and varactor diode. Then the RF signal is amplified by a set of multiplier tank circuit and a final buffer.
Power is supplied by a 9 volt battery. The green line is a simple wire antenna. A short piece of RG174 could also be used to a SMA jack is you want to get fancy. The output is around 100mW.
The board was etching using toner-transfer/iron-on process.
It was a fun experiment.
Pete
KEØBRS
