Octago
Member level 1
Normally when we analyse a circuit, the small signal model is always used to explain the input impedance, gain...etc
But actually the input signal of a circuit is often relatively large,therefore it is not a "small signal" anymore.
At this time could we still use small signal model to explain the behavior of the circuit? If not, the large signal analysis which is about the DC operating point and so on can not be used to explain the complete circuit behavior?
So I am wondering when is the small signal analysis applicable? when the large signal? and in which case should I use small signal analysis and large signal analyis respectively?
