vicky29
Member level 4
double op-amp
Hi friends,
Recently in a op-amp book i read feeding an analog input to a non-inverting pin of a op-amp is not a good idea and less accurate than if feed to inverting pin. Actually i need to amplify a analog voltage from 0 to 0.5 volts to 0 to 5 volts for which i used the single opamp circuit as shown below. should i use double op-amp circuit )also as shown below) for more accuracy) first stage of opamp is a inverter with GAIN=-1 and second one is with Gain = -10.
Thanks
Hi friends,
Thanks
