SMA/SMB footprint in Orcad 16.5
sns22
Member level 2
Member level 2
Spain
Hi all,
I going to use a SOCKET, SMA, RIGHT ANGLE, 50OHM in my PCB link here https://uk.farnell.com/te-connectivity-amp/5-1814400-1/socket-sma-right-angle-50ohm/dp/1248989
I was able to find the smb_90.dra and smb_90.psm files in the Allegro Starter / Evaluation Library Cadence_Starter_Library Downloaded from the Cadence web page https://www.cadence.com/products/pc...2.aspx?regid=da188902c34d49be8fb3ffd88351b2d4
However there is no padstack available for same.
Can anyone tell where to get the footprint for the connector?I put these files in the C:\Cadence\SPB_16.5\share\pcb\pcb_lib\symbols. When I add the pcb footprint in my design The design check rules works good. But when I try to create a netlist in the design I get a
WARNING:(ORNET 1119)NO spice template ignoring. And it ignores the connectors in Orcad Capture.
Can someone help me with the footprint for the same.
Sneha
Hi Snehanidhi,
Why don't you create it by yourself.It is a simple footprint.The datasheet is with recommended footprint.
You can save lot of time if you create it yourself, instead of searching.
Try yourself,if you have any more questions post it here.we will try to resolve it
Learning how to do footprints and manage your library is a absolute requirement for a PCb designer, I would also look up IPC_7351 and "The CAD library of the future".
