SMA edge board connector model in HFSS or CST
yzriver
Member level 2
sma connector model
Can any one have SMA edge board connector model in CST or HFSS. or the meterial parameter and dimension of the SMA edge board connector?
thank you.
Added after 5 hours 22 minutes:
and how to draw a bonding wire in HFSS, not using the provided tool in HFSS. I mean a random wire, not set with data input?
Added after 1 hours 42 minutes:
how to set the material for the bondwire in CST?
connector hfss example
It is helpful if you have had the reply, plz post it here, thanks.
hfss models sma
To create an arbitrary wire you can sweep a circle along a curve. The curve can be created in a variety of ways, including "equation based". You could also do it freehand with a polyline..
sma adge
I had to design once a SMA feeder together with an antenna using MWS.
I simply downloaded a SMA datasheet from a manufacturer
and got information about its size and the properties of the
insulator (er, losses, etc.).
I interfaced the SMA connector with the
antenna using 'wires' of finite diameter provided within MWS.
Polyline is also another equally effective alternative - you then simply
convert it into a wire of finite diameter.
I simulated the structure in MWS and tested it in the lab. The similarity
of the S11 between them, was just so close.
board sma connector
SMA could be created in similar way as a coax connector in the HFSS example from the user guide posted on edaboard more than a year ago, I think it was version 9.2.
