SLS switch-level simulator downlload
jimjim2k
Advanced Member level 3
Hi
SLS is a switch-level simulator that can be used to simulate the logical and timing behavior of digital MOS circuits. In the simulator, transistors are modeled by grounded capacitors and a switched resistor. Each node in the network has a logic state O, I or X (for unknown), and each transistor has a state on, off or undefined. Many characteristics of MOS circuits can be modeled accurately, including: ratioed, complementary and precharged logic; dynamic and static storage; pass transistors; busses; and charge sharing. Because the simulator is a local-event-driven simulator, also large networks can quickly be simulated.
1. h**p://dutentb.et.tudelft.nl/research/sls-text.html
* -> t
tnx
