Slowness in IC Waveform affirma windows in 24 bit
dariorusso
Newbie level 2
Newbie level 2
Hi all.
Im running IC5.0.32 at 24 bit under linux with ati radeon. Everything seems going well, but display is really slow when i move the crosshair marker in the waveform window. Even the square following the mouse is slow or jumping, really not smooth, indeed. The problem is solved when i run the Xserver at 8 bpp, BUT, when i move the mouse through different windows colors go crazy making impossible to work. I found that, running cadence without the Windows Manager, everythink is ok, but naturally, no way to move the windows. I think the problem is the palette changing of motif libs. However, 8 bit is the extreme solution i wish i could avoid. 24 bits solution is worse on a pc with i845 graphics card, where also moving transistor is impossible. Anyone found a solution??? Anyone had even encountered this problem?
Thanks in advance.
Eng. Dario Russo.
your graphics card's performance is very poor. you can upgrade it or use 256 color..
My graphics card is an atiradeon 9600!!! its really fast in 2D and in 3D,too. I assure that's a cadence problem!! As i said, in 256 color, i cannot work for palette changes.
Search the forum first, this problem has several times been asked here e.g.
